Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gas air compressor vs electric
Old 05-02-2013, 10:38 PM
67Elcamino's Avatar
67Elcamino 67Elcamino is offline
Originally Posted by 65ELCMO View Post
That is a vertical tank that soneone took 2 compressors and welded on.
That looks like a 8 or 11 horse honda look on the case for a number starting with GX. That is the engine series and three numbers will be the size ie 240. 360, etc
The compressor looks imported. The tank is worth the money you paid. Keep it for additional air storage.
The motor is a GSX240-242 Is this 7 hp? Im just wondering what PSI it should build up to before it begins releasing air or stop turning the compressor.
Here are some close up pictures of the location where a run unloader would be located. I dont see a run unloader but do see a clutch on the Honda motor. How does this clucth operate? does it disengage after so much back pressure from the compressor?
ID:	73728   Click image for larger version
