Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gas air compressor vs electric
Old 05-03-2013, 02:38 PM
67Elcamino's Avatar
67Elcamino 67Elcamino is offline
Originally Posted by timothale View Post
On both my twin tank construction compressors the electric motor and the gasoline engines run all the time, the unloader lets them idle. the gasoline one drops the rpm. the elect, one continues at rated rpm. That looks like a clutch from some type of go cart. There should be some type of pressure controlled throttle .
I doubt it has any type of pressure controlled throttle because I dont see any wires or hose going from the tank back to the motor.
Would it be possible that the pressure building from the compressors make the motor idle down?
