Hotrodders Bulletin Board
#1
gas cap leaks
I have a new street rod and the aftermarket gas tank (I don't know the brand). The cap seems to fit tight but when it is full the gas runs out when I accelerate or turn right.
Do the gas caps need to be vented? Can you recommend a good cap? Thanks |
#2
re gas cap leak
Change the cap first. The tank should have a factory built vent on it allready. You don't add vents. It might be the wrong cap or it is bad, I had the same problem on my 70 model, I just changed the cap and I had no more problems.
#3
More likely
a bad seal on the cap. Or even the wrong cap for that tank.
Tazz |
Back to top |
Similar Threads for: "gas cap leaks"
| gas cap filler assembly | Ruha | Body - Exterior | 5 | 07-29-2005 11:25 AM |
| Help Please? 87 Dodge mini-ram van - stalling if little gas applied | jojo99 | Engine | 3 | 07-27-2005 06:19 PM |
| want cheaper gas prices?? plz read this | sherfield2002 | Hotrodders' Lounge | 7 | 03-12-2004 05:22 AM |
| gas cap vented? problem or not | catscan4free | Engine | 8 | 02-26-2004 04:24 AM |
| early optispark vacuum source | 48Man | Engine | 7 | 01-16-2003 01:17 PM |
