Gas cap problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2012, 11:31 AM
dilligaf's Avatar
Gas cap problem
I have a Wisco products gas cap on my fuel cell. It is very hard to get on and off. I have to use a screw driver to pry it off. I contacted Wisco products and I could have got better results talking to a rock in the back yard. Has any one out there experienced this kind of problem. If so, how did you fix it.
Old 11-18-2012, 12:10 PM
techinspector1's Avatar
Wiki Edits: 326
I'd probably do a little surgery on the cap with a very sharp X-Acto knife. The receptacle may not be exactly right, like maybe it's tweaked and the cap won't fit exactly right. Here's the install video.....
Old 11-18-2012, 12:15 PM
life is a temporary assignment
I never seen one that was easy..
Old 11-18-2012, 01:16 PM
dilligaf's Avatar
Wisco cap
I cannot see where it is hanging up so I don't know where to start cutting. At first I thought it might be the metal tabs but now I am not sure. It seems like it should be an easy fix but nothing jumps out at me to fix.
Old 11-18-2012, 01:55 PM
Not sure.. All the ones I had I just lived with it and never really looked into why..Sorry.
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
dilligaf (11-19-2012)
Old 11-19-2012, 07:56 AM
dilligaf's Avatar
Gas cap hung up
I got out my box cutter and went to work. It worked. I also took the metal tabs down a bit on my belt sander. The problem seemed to be the sharp edge of the metal receiver that the cap goes into. I probably could have removed it from the fuel cell and smoothed it off and it might have worked, but I had quite a bit of fuel in the tank and I didn't want to work with the nuts and bolts over the open filler hole. Thanks for the input.
The Following User Says Thank You to dilligaf For This Useful Post:
NEW INTERIORS (11-19-2012)
Old 11-19-2012, 06:12 PM
Thanks.. I will take a look at my next one.. Glade you got it done..
Old 09-08-2015, 04:27 PM
GWB 3's Avatar
I also am having Problems with the filler cap. I e-mailed Wisco and received this replay:
I would go to Coyote Gear's website and buy a new cap on-line They even have free shipping
gas cap venting? db flyer Engine 1 05-12-2011 12:24 PM
vented gas cap cares General Rodding Tech 2 07-15-2006 12:45 PM
Gas cap anyoldchevy Body - Exterior 1 02-01-2005 05:31 AM
gas cap vented? problem or not catscan4free Engine 8 02-26-2004 04:24 AM
I'm looking for a lockable gas cap elukas Engine 2 08-11-2003 10:17 AM
