Gas consumption - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2008, 08:45 AM
stoney 81ta's Avatar
Gas consumption
Hi all,I have a 81 TA with a 305sbc,mild cam headers and dual exhaust,change the origanal carb to a edelbrock 600cfm carb last year,gas usage was ok then,This year seems to be burning more gas than usual.Any ideas?.Thanks all.
Old 08-15-2008, 08:53 AM
mcharger440's Avatar
get the big hammer
not a clue all of my experiance with edies were better milage and worse performance mabey just higher prices makin it look worse?? lol??
Old 08-15-2008, 12:09 PM
first question is which 600cfm Edie model?
1406 is set up for more for economy with .098 primary jets and "fat" 75/47 rods to restrict more flow thru the jet....
the other 600cfm model (1405?) is set up stock more for perfomance with something "like" (dang CRS!) .100jets and 70/37 rods(???)
at high Hg light gas pedal cruise, .098-.075=.023 wide "donut shaped hole" opening for gas to flow thru....
the other carb is .100-.070=.030 wide donut hole....
(the tuning charts in the manual save you the aggrevation of calculating the actual area of each donut to be able to make a flow percentage increase compare to each other)
Old 08-15-2008, 01:02 PM
I have the 1406 model
Old 08-15-2008, 01:30 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
good point
or maybe the higher ethanol content? Plus I read elsewhere that some gas stations are mixing water?? I find that hard to believe.. they said it will mix due to the alchohol??
Old 08-15-2008, 03:16 PM
how weird!
I received your reply on 3 emails and all 3 said 1405....
thread says 1406....
very slim chance that your motor will like any leaner than the 1406 settings,,,,you will need to use more gas pedal to get the same amount of acceleration TQ
Suggestion????:
a pretty simple to do dynamic test for how well is the whole rotating system sealing and operating is rig a vac guage so you can read it while driving....
note that the Hg values given on this animated vac guages link are more correct for a stock camshaft
http://www.users.bigpond.com/ergoff/vac1.htm
first and foremost you want to see a almost rocky steady needle when it's static or while moving....
with a mild cam there should be 24Hg+ on a downshift if the rings and valves are sealing
while you've got the vac guage hooked up:
your old carb metering may have better matched your present timing total and made a higher Hg at hwy speed....
try adjusting your vacuum advance for more or less total timing to see if you can't get a higher Hg....
very very roughly each additional Hg on the hwy is worth up to 2mpg....
Old 08-17-2008, 11:38 AM
E10 fuel knocks your mileage 6%, more or less, and usually makes the engine run worse.
Buy real gasoline. We have only 2 stations in the whole county with real gas.
gas Bob C Off-Topic 10 03-06-2008 07:28 AM
acetone in gas mb42588 Introduce Yourself 1 10-06-2005 06:46 AM
A little perspective on gas prices Centerline Hotrodders' Lounge 24 05-23-2005 02:50 PM
AV gas Chevy Thunder2 Engine 51 03-21-2004 12:26 PM
want cheaper gas prices?? plz read this sherfield2002 Hotrodders' Lounge 7 03-12-2004 05:22 AM
