Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - gas doors / hammerforming/ and a gas door question
Old 01-26-2013, 01:58 PM
RLDSL RLDSL is offline
The shape of that door is super unique,and it looks like the geometry just might work.... have you thought of trying a short length hinge set on the diagonal in the bottom right corner, to where it would pull out to the right and down ( small hinge with hoops )? that would look insanely cool ? of course a large one with hoops in the orientation you are in would solve teh hitting problem as it would lift the door out and away. Very easy to make with a chunk of sheet metal and some heavy wire.
