Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - gas doors / hammerforming/ and a gas door question
Old 01-26-2013, 06:11 PM
496CHEVY3100's Avatar
496CHEVY3100 496CHEVY3100 is online now
Built Not Bought
Last journal entry: 53 ad3100
If i understand correctly sounds like you could use a small rubber bumper like the ones inside glove box on older chevys ,just drill a 1/8 hole in hinge and pull the rat tail thru hole leaving the cone shaped rubber to adjust height trim rubber to fit. Good luck..
