gas doors / hammerforming/ and a gas door question
so I'm doing a 1955 300 and I was doing mud for about a week straight, and I always lose my mind when I do it for too many days in a row, so on Friday I just knocked out a door in the morning and decided to mess with this gas door.
The customer wanted this but there's no lump in the door on the car, and he couldn't find another gas door. http://i1183.photobucket.com/albums/...h/P1130460.jpg I thought this would be a great idea to try hammer forming. I've always heard about it but never saw a situation arise where I determined it needed. So I lined it up on the car and marked it where I thought it should be. I also measured the height of the lump on a gas door in the parking lot. It was 1/2" http://i1183.photobucket.com/albums/...h/P1130435.jpg clamped and ready to rock! http://i1183.photobucket.com/albums/...h/P1130436.jpg http://i1183.photobucket.com/albums/...h/P1130437.jpg so basically I just hammered into the void with the pick end of my hammer and loaded the pick with so much tape it never broke thru. Turned out great! http://i1183.photobucket.com/albums/...h/P1130444.jpg now the other problem...no matter how I adjust it, spoon it, etc, the thing opens too much. It will scratch the paint and rest right on the gas door opening. I'd rather not cut a slice into the opening cause it opens so far that the gap would be ridiculous just to make it work. So I'm thinking maybe if I hammer down the metal curled around the pin where it pivots maybe it would tighten it up? Or perhaps even a little chain to stop it before it hits. Any suggestions? I should have taken a pic of the backside, my apologies. |
Shorten the length of the hinge by maybe 1/8 to 3/16's
never thought of that. Wouldn't that also make it sink in that same amount when it's closed? Or at least in the rear where there's no rubber stop.
Kind of scared to try to be honest but it does sound promising. Now that you got my mind thinking like that, I think the darn thing on the bench was able to open all the way physically possible. So not sure if that would work. |
Build a stop on the leading edge the distance ya need to keep it up.
I think I might try your idea of shortening the hinge, but first I'm gonna take it back off to check the amount of travel. I can always adjust it and spoon it around after if it doesn't fit the best after doing that. the main issue is the back hitting. will probably cut it and just overlap it with two tacks to mock it up and while on the car, then take it off, scribe, cut and final weld. Not so intimidating once I thought about it for a sec. Thanks for the response.
If ya overlap it, it's gonna throw off the height or depth depending which side you overlap top or bottom
If that makes sense. |
I don't understand where it is hitting, you mean down in the bottom of the hole when it opens the leading edge of the door is hitting in the bottom of the recessed area of the quarter? If that is the case you need to move the pivot point nearer the edge so it swings out more like a gate, if the hinge pivot point is back away from the edge the front swings in like a door the car swing in the front edge. So moving the pivot point forward is what it sounds like you need.
And that pivot point needs to be as close to the skin of the lid as possible. The further away from the skin the more the lid will move forward before going in at the front needing a wider gap. Is that where you are, am I understanding this? Brian |
Your hammer forming looks great by the way.
Brian |
it just opens too far. Yeah it does hit at the bottom recessed area/jamb of the opening but I think that's cause it's opening too much and when it hits the recessed area it's at the end of it's travel, right before the door completely rests on the opening edge. (The middle of the door rests right on the edge of the opening). It's pretty much what's stopping it. I'll take some pics of the inside of the door on Monday and work around it so I can get more opinions from you and others.I'll take a pic of it opened too.
Sounds like a stop off the hinge going back for the door to hit would do the job, as long as it's opening enough to get the new modern clumsy crap nozzle we have to use here in sunny California.:drunk:
Brian |
The shape of that door is super unique,and it looks like the geometry just might work.... have you thought of trying a short length hinge set on the diagonal in the bottom right corner, to where it would pull out to the right and down ( small hinge with hoops )? that would look insanely cool ? of course a large one with hoops in the orientation you are in would solve teh hitting problem as it would lift the door out and away. Very easy to make with a chunk of sheet metal and some heavy wire.
If i understand correctly sounds like you could use a small rubber bumper like the ones inside glove box on older chevys ,just drill a 1/8 hole in hinge and pull the rat tail thru hole leaving the cone shaped rubber to adjust height trim rubber to fit. Good luck..:confused:
Well tec, Its all over now ,and theres no going back....You are now a metal shaper...Figuring this kind of stuff out is one of the reasons its so addicting ....Just one problem....when you said "bend" the hinge...Your new term should be "reshape" the hinge....Bending sounds so.....cavemanish
Judging by the pic it looks like the door is a little to far forward and the gao is a little tight so Imagine your sticking a screwdriver in the gap and twisting it so the gap opens up....which way is the hinge going to bend ...the rest is up to you....:mwink: |
I'm such an accomplished metal shaper now I'm taking my gas door to Chip Foose and demanding a job! I think I got a bunch of ideas to at least visualize when it's back in front of me. I'll come up with something to "fab" up. :D |
| All times are GMT -6. The time now is 02:51 AM. |
