gas filler - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2007, 04:16 PM
41 kustom's Avatar
gas filler
I would like to put the filler neck and cap in my trunk. I know what your thinking, is this guy nuts. I'v seen it in a lot of car books but thay never get into details. I know you need a sealed cap of some kind, but what do I do with the vent. Any one who has done this please let me know. Thank you.
Old 01-18-2007, 05:00 PM
boatbob2
fuel filler cap
Hi,after you remove the fill tube from the gas tank,i would braze a piece of copper tubing (small tubing 1/8?) to the fill tube,close to the trunk floor,and either run the tube thru a small hole leaving it down 6 to 8 inches, and aim the tube toward the rear of the car. or add a piece of gas hose and run it thru a hole in the trunk floor. im boatbob2
Old 02-08-2007, 11:19 AM
Use a sealed cap w/ no pressure relief valve built in & splice in a small line of tubing from the main hose that runs outside of the vehicle. In the racing industry we use a $16 1 way check valve found at Summit or a similar company that you install within the hose.
Gas Thieves!!!! Weimer Hotrodders' Lounge 28 03-03-2010 03:46 PM
All you Filler Experts satexasf150 Body - Exterior 1 02-10-2006 12:36 AM
relocating gas tank out of truck cab murrsue General Rodding Tech 6 02-26-2005 02:12 PM
Gas filler options JhnBrackett Body - Exterior 4 01-03-2005 02:32 AM
want cheaper gas prices?? plz read this sherfield2002 Hotrodders' Lounge 7 03-12-2004 06:22 AM
