Gas filter - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-28-2011, 06:58 AM
Wiki Edits: 31
The HPG-1 filter is an old diesel fuel filter, that got put into the aftermarket. other companies make filter elements because they were used in stock applications.. But it is still a diesel fuel filter..
I have a brand new HPG-1 kicking around somewhere, bought it and then found out it wouldn't work for what I needed
  #17 (permalink)
Old 04-28-2011, 11:31 AM
fuel filter
Thanks user151. I think I will go with the ROBBMc since it uses NPT fittings and that is what I am set up for. I believe the Russel uses -AN fittings.
Changing the filter in the FRAM HPG-1 fuel filter assembly tombguard Hotrodding Basics 3 08-18-2009 06:24 PM
Looking for a fuel filter cover or a metal fuel filter. Suggestions? (pic) rajsid Engine 3 08-05-2009 07:31 PM
pvc filter??? aceofspades49c Engine 3 11-14-2005 06:00 PM
Milodon oil pan...7 qt w/ filter or + filter? Finmike Engine 6 07-05-2004 10:44 PM
Oil filter help daveh Engine 3 03-10-2004 01:46 PM
