Gas fouling plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2006, 09:44 AM
New Member
Gas fouling plugs
Help with engine gas fouling plugs. This is a new engine 427 sbc 500hp alum. head 750 holey carb. chevy HEI with 50,000 volt coil. This engine will gas foul the plugs if you let it idle for a short time over a few times starting and runing. I am using ac#41-629 plugs. Thanks Turkey
Old 09-09-2006, 04:54 PM
runn141's Avatar
ac is a good plug the holley shouldnt be too much for a big block. is it a double pumper?
Old 09-10-2006, 02:02 AM
FREE TRAMAMPOLINE!!!
if the carb is running mega rich it will foul the plugs. Try setting the mixture and idle screws again.
Old 09-10-2006, 05:28 AM
steve t's Avatar
ex biker, now hotrodder
make sure your coke is open all the way, carb may be leaking into intake at idle
Old 09-10-2006, 05:41 AM
poncho62's Avatar
Wiki Edits: 5
Sounds to me, you need more spark......Maybe a MSD system.
Old 09-10-2006, 09:40 AM
67 Deuce 4 Me's Avatar
Bowtie or Die!
If your just running it for a few minutes and not letting it get hot. Doing that several times in a row you will foul plugs with that engine. I know because it happend to me. Pulling my car in and out of the shop and not driving it or letting it get to operating temp kills plugs in a engine like yours. I thought I had some other problem like carb or tuning spent a bunch of time and money when I relized it was the short run times over and over. This may not be the case with you but it was for me.
front plug fouling Knobie Engine 16 12-01-2005 06:19 AM
Help Please? 87 Dodge mini-ram van - stalling if little gas applied jojo99 Engine 3 07-27-2005 06:19 PM
A little perspective on gas prices Centerline Hotrodders' Lounge 24 05-23-2005 02:50 PM
AV gas Chevy Thunder2 Engine 51 03-21-2004 12:26 PM
want cheaper gas prices?? plz read this sherfield2002 Hotrodders' Lounge 7 03-12-2004 05:22 AM
