Gas Gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2007, 11:00 AM
daveh's Avatar
Gas Gauge
Hi guys I'm not sure what section to place this in so if this is the wrong one sorry.
I just finished replacing the gas tank and sending unit in my 69 camaro. The changeover went great. However, the gauge is not functioning accurately it is off by a 1/2 a tank. When it reads empty it's half full. What can I do? Thanks for your help.
Dave
Old 07-16-2007, 11:52 AM
Big Mouse's Avatar
Stroked Z28
On the laster Camaros, I know that the sender units have different resistances across the wires - so if you have the wrong sender, it can impact how your gauge reads.
Throw a multi-meter on your fuel sender wires to see how it reads. It should match your old sender unit's resistance. If not, you have the wrong sender unit.
Old 07-16-2007, 01:30 PM
daveh's Avatar
Thanks I thought of that and it's the correct sender.
Old 07-16-2007, 05:28 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
  • 1 ) Bend the Float arm to match the gauge.
  • 2 ) Install a rheostat within the range resistance of the sender, calibrate it for "0" at 2 gallons, then seal the shaft (so it won't move OR leak) and mount in a dry sturdy place along the sender wire between the rear and front.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Incorrect Gas Gauge locomark Electrical 2 11-04-2005 05:45 PM
87 Camaro - Gas gauge stuck - FULL dpjmw Electrical 12 06-07-2005 09:04 PM
Gas Gauge sscamaro_510 General Rodding Tech 11 12-29-2004 05:02 PM
gas gauge mysteriously starts working again bullheimer Electrical 11 02-13-2004 06:12 PM
Gallopping Gas Gauge Blues jpd37 Body - Exterior 2 02-05-2003 09:40 AM
