gas gauge 89 ford f250 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2010, 10:27 PM
gas gauge reads way past full, when u turn on the key. what is causing this has two tanks
Old 04-11-2010, 06:41 AM
dei8fan's Avatar
Registered Brain Surgeon
The wire to the sending unit shorted to ground will do that.
Old 04-12-2010, 06:04 AM
I got that symptom on one tank when an installer accidentally caught one of the sending unit wires between the frame and a trailer hitch he was bolting on.
If it is one of the individual tank wires, you should only get the problem on one tank or the other. If you get it on both tanks, the wire is grounded before it connects to the solenoid. That means its probably the wiring that runs from the dash to the solenoid under the truck.
Bruce
using 20 gauge without gas Slickriffs Body - Exterior 9 10-19-2007 09:11 AM
gas gauge help bow tie guy Electrical 3 06-05-2007 03:34 PM
GM Gas gauge poncho62 Electrical 7 01-06-2007 06:06 PM
Gallopping Gas Gauge Blues jpd37 Body - Exterior 2 02-05-2003 09:40 AM
replacing gas tank in 29 Ford pikalpha Engine 2 12-10-2001 05:45 PM
