Gas gauge not working, what to check? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2009, 05:31 PM
Hello guys hope this is the right forum area. I have a 96-chevy s-10 that I got last summer and since I have gotten it my gas gauge has never worked and I don't know what to check. I have moved the bed back and checked the top of the sending unit in the tank and the wire harness is still hooked up to it but my gauge does not work. The gauge is stuck way past full. The truck currently has a 350 vortec in it right now but still the fuel gauge should still work should it not? What can I do to check to try to get it working again.
Thanks for any help Eric
Old 01-19-2009, 05:43 PM
poncho62's Avatar
Wiki Edits: 5
Usually when the "way past full" is going on, it's that the ground that goes from the sending unit to the frame is broken .......There are 2 wires....one from the sender terminal to the gauge and another that grounds the sending unit to the frame.
Ontario Rodders
Old 01-19-2009, 06:01 PM
Cool thanks for the info I will have to look around when its warmer outside. I live in Ohio and its been really cold outside and don't have a garage to work in wise. I read that usually if its way past full its a short somewhere. I will check. Thanks Eric
Old 01-19-2009, 06:22 PM
whinny's Avatar
66 mustang
hi eric
i had same problem with 66 stang,on top of tank there is a 4 inch round doofery that goes into the tank, unscrew the 6? screws and take the part to your local calibrating shop and have it reset, cost me bout $40 from memory,all fine now.
Russ
1969 Camaro Gas Gauge jgreene6611 Engine 2 10-17-2007 07:31 PM
GM Gas gauge poncho62 Electrical 7 01-06-2007 05:06 PM
gas gauge stuck? or bad? 72chevyhotrodder Electrical 4 02-13-2006 05:35 PM
Gas Gauge Full when not full (short?) 1Fast65Elky Electrical 11 01-01-2006 05:31 PM
sending unit/ gas gauge incompatibility murrsue Electrical 3 03-03-2005 08:02 PM
