Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 08-20-2008, 11:25 AM
Mertz's Avatar
Mertz Mertz is offline
Gas gauge problem
I have a 1972 Chevy 3/4 ton with the gas tank behind the seat. Just before going on vacation the gauge read properly. The day I am leaving the gauge drops from what I know I have in the tank to about empty. The gauge does move a little when the gas slushes around in the tank. I fill the tank and the gauge pegged at empty. As I use gas it starts to move again.
I put in a new dash panel and repainted the gas gauge needle. I pulled the needle the first time I worked on the panel and was off a little in my readings so I redid it. I was having a problem getting it back to ready correctly until I set the needle to full and replugged in the power connection to the panel. It worked that way for about a year.
Would it be possible to disconnect the battery and use a magnet to position the needle and reconnect the battery and have it read correctly or is there another prceedure for setting the needle? I am guessing that becasue it does move the sensor in the tank is working.
Any suggestion would be appreciated.
Old 08-20-2008, 11:45 AM
F&J F&J is offline
re: Gas gauge problem
Just from reading this two or three times, I would think it is a problem with the windings on the tank sender.
There is a flat strip with fine wire wrapped around it. Then the contact point on the swinging arm rubs on a particular part of those windings. It is possible that at some different gas levels, that they are not making a good contact.
You could test that theory by keeping an ohmmeter hooked up to the sender while slowly filling the tank. (disconnect the wire, and test the sender only).
Or, take the sender out and manually work it slowly to see if the ohmmeter shows some bad spots.
Old 08-20-2008, 01:59 PM
burnt olds burnt olds is offline
Gas gauge problem
take the wire off at gas tank , jumper wire it to good ground , if it moves the Gage , its your sender .
but check to see if tank is grounded first ,it lies in rubber strips and bolted in , rust or corrosion .
ohm meter it to check for ground .
you could also jump tank to good ground first , to see if gage rises to your known fuel level .
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Gas gauge problem"
Unusual Vehicle Gauge Problem. M&M CUSTOM Electrical 4 08-06-2008 05:32 PM
Poor gas mileage problem ken47 Engine 3 03-19-2007 06:56 AM
GM Gas gauge poncho62 Electrical 7 01-06-2007 05:06 PM
gas gauge stuck? or bad? 72chevyhotrodder Electrical 4 02-13-2006 05:35 PM
Temperature Gauge Problem draft Electrical 4 08-30-2004 10:34 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
