Gas Gauge Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2010, 04:38 PM
Retiredrich's Avatar
Gas Gauge Question
This is on my 61. My gas gauge was working okay until I tried to eliminate a different problem. The brown wire on the gauge goes to the sender and the tan to the fuse box. The starter kept barely engaging the starter drive when I shut the engine off so I pulled the ignition switch and removed the pink accessory wire from the switch. This solved the starter drive barely engaging problem but I lost my gas gauge. Prior to buying a new ignition switch, I'm guessing I need to give power from the fuse box to either the brown or tan wire when the ignition switch is turned to on/start. That's my guess, but which one do I need to do it to? Thanks, Rich
Old 05-06-2010, 04:54 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Nope.
That wire that goes to the guage is a ground.
If you touch it to bare metal, the guage should read full (or empty) ... whatever is opposite of the guage in "key off" mode, I think.
Something is telling me "Check grounds" ... as that is often the source for a lot of weirdness.
Your negative ground cable from the battery does connect directly to the engine, right? Do you also have a seperate (wired) ground connection from the engine to the frame?
Old 05-06-2010, 05:28 PM
Gas Gauge Question
Like I said in the beginning. The gauge worked until I eliminated the starter problem so now I just want to know which wire on the gauge wants power. I can either put the accessory wire back on the switch or buy a new switch and the gauge will work again. I want to know how to get the gauge working without putting the wire back on the switch. In other words, not buy a new switch and still have a gas gauge that works.
Old 05-06-2010, 06:36 PM
Gas Gauge Question
I'll go buy a new switch tomorrow. Oreilly's has it in stock.
using 20 gauge without gas Slickriffs Body - Exterior 9 10-19-2007 08:11 AM
gas gauge help bow tie guy Electrical 3 06-05-2007 02:34 PM
GM Gas gauge poncho62 Electrical 7 01-06-2007 05:06 PM
Strange Question about Gas Fumes & Explosions TheBreeze Hotrodders' Lounge 10 12-11-2005 09:07 PM
my gas gauge dont work....help notmrgoodwrench Electrical 2 09-02-2004 07:41 PM
