Gas Gauge Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2011, 04:56 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Gas Gauge Question
When I first start my truck, my gas gauge always reads about 1/8 tank fuller than it does after the engine warms up.
I don't get it. Can anyone explain why that's happening?
Thanks.
Alan
Old 06-07-2011, 05:51 AM
On start up the alternator ( or generator ) puts out close to 14 volts, when it warms up and the battery is fully charged, the voltage will drop to below 13. This will cause the old style bi-metal gauges to change readings. I don't know what type gauge you have, but the newer type gauges are unaffected by voltage changes.
Old 06-07-2011, 06:31 AM
T-bucket23's Avatar
Wiki Edits: 26
Thanks.
Alan
In a lot of vehicles the temperature gauge and the fuel gauge are fed from the same power source. In a lot of older cars there was a voltage regulator for the gauges and there would be a little interaction between the temperature and fuel gauges
Chet
Old 06-07-2011, 06:35 AM
horvath's Avatar
Thanks, guys.
I have Dolphin Gauges in my truck ... not older stuff.
See the 5 Inch Quad w/Electronic Speedo here:
http://www.dolphingauges.com/dolphin_gauges.html
Is there something I could add to the wiring to get a steady (accurate) reading?
Alan
Old 06-08-2011, 06:19 AM
carlk4728's Avatar
If the issue is higher than average voltage during engine warm-up, then you could install a voltage regulator between the gauges and their power source. Just make sure that you get a regulator that can handle the amperage required by your gauges. If you do decide to take this route, remember that the regulator will create another possible point of failure for your fuel gauge, or, if your pod has a single power source, your entire cluster.
Old 06-08-2011, 09:49 AM
horvath's Avatar
Thanks. I guess, now that I know what's happening, I'll just leave things as they are.
My question now, however, is this: Which is the "true" reading? At 14 volts? Or at the lower voltage?
Alan
Yet another Fuel Gauge question hot_rod_kid Electrical 3 04-16-2011 07:13 PM
Oil gauge question? Jag Daddy Electrical 2 03-19-2011 05:37 PM
GM gauge question Eric64 Electrical 4 01-28-2011 05:10 PM
Gas Gauge Question Retiredrich Electrical 3 05-06-2010 06:36 PM
Question about fuel gauge ??? Robbie Electrical 4 06-06-2009 08:31 PM
