gas issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2010, 08:48 PM
gas issue
i have a 85 el camino with a 4.3 tbi. i replace it with a 350 carb. do i have to remove the old pump in the tank to install a elctric low psi pump on the side
Old 09-28-2010, 08:56 PM
you could use the same electric pump but you will need a regulator and a bypass so the excess fuel can go back into the tank. You only need about 4-6 psi for a carb. The pump you have now makes way too much PSI for a carb. I have a sbc 350 in an s-10 that still has the old electric fuel pump in the tank, and I put a mechanical pump on the engine, without removing the old pump. Most of the in line fuel pumps like to push fuel, not pull it. It is best to be mounted near/below the tank, if you go this route. Hope this helps!
Chevyguy13
Old 09-28-2010, 09:47 PM
thanks. but i tried a low psi pump electric n nothing happens
welding on gas tank oldred Hotrodders' Lounge 15 01-21-2012 10:49 AM
GAS PRICES ARE GETTING CRAZY! READ THIS AND HELP THE PROBLEM dont pump on May 15TH chevymastermind Off-Topic 106 05-25-2007 07:34 AM
Got Heads! Unleaded gas problems? steveyb4342 Engine 25 05-08-2007 06:15 PM
Who Said No Such Thing As Bad Gas 1BAD80 Hotrodders' Lounge 4 11-20-2004 08:04 PM
Question about gas grade??whats best?? Robbie Engine 18 07-09-2004 10:59 PM
