Gas leaking from carb, which gasket do I replace? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2009, 06:22 PM
I have a Holley 750cfm with Vacuum secondary. When you pump the pedal you can see a little bit of gas around the shaft of the butterflies. I'll try to explain it a little more. When you connect the throttle linkage to the carb, its that shaft but on the other side of the carb. If the electric fuel pump is on, it doesn’t leak. But once you push the pedal you can see a small amount of gas around the outer edge of the shaft. The car has dual carb and the rear plugs have been really black. So it is leaking even more inside. I took the carb apart but wasnt sure what gaskey is causing the issue or if it even is a gasket issue.
Thanks.
Old 01-05-2009, 06:39 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Throttle bushing very wornout?
Old 01-06-2009, 07:09 AM
I jsut bought a rebuild kit, so I'm guessing that all the gaskets are included. But I'll try to look for that bushing.
Thanks!
Old 01-06-2009, 04:56 PM
The Maintenance Geek
You won't find the bushing in a rebuild kit, it needs to be machined...
K
Leaking booster-Holley Carb corvette77 Engine 2 10-02-2008 02:23 AM
WARNING Mr Gasket Fuel Filter Problems SilverFox2 Engine 11 09-08-2008 04:36 PM
Harley- Gas Leaking into Primary??? 71gtx Engine 5 04-23-2008 08:48 PM
leaking head gasket? Festive57 Engine 11 10-17-2007 11:03 AM
Can I replace two barrel carb with four barrel on chevy 305 maverick19642001 Engine 6 02-20-2004 10:00 AM
