Gas pedal is going down beyond my control - EFI, 200R4 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-12-2011, 04:44 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
HERE is a link to a side mount conversion kit. It allows you to use standard small block chevy side mounts if you wish to change.
Semper Fi
  #17 (permalink)
Old 12-12-2011, 04:55 PM
LATECH's Avatar
Is the cruise control hooked up? Maybe it is going crazy. The engine mount thing also sounds quite plausible.
  #18 (permalink)
Old 12-12-2011, 05:21 PM
T-bucket23's Avatar
Wiki Edits: 26
This used to be a common issue back in the 70's. broken mount would pull and bind the linkage. I remember some of the chevies ad a little cable added to the drivers side engine mount.
Chet
  #19 (permalink)
Old 12-12-2011, 05:48 PM
RWENUTS's Avatar
If it's an original 265 you might not have provisions on the side of your block for side mounts. Side mounts for the tranny will work.
  #20 (permalink)
Old 12-13-2011, 01:00 AM
yaww's Avatar
Last journal entry: Modification of your pedal to "power brake"
Yes, you are right, i couldn't find a side mount kit for 55-57 engines, they are only for 58 and up SBs. I will try side mounts of tranny, but now will have clearance problems with gear linkage. Lets see, one challenge triggers the other
  #21 (permalink)
Old 12-13-2011, 08:24 PM
RWENUTS's Avatar
I hear you on the side mount mods. Been there too. You could replace the front mounts with a motor plate like in this link. Not optimum but would work.
http://www.jalopyjournal.com/forum/s...d.php?t=256724
  #22 (permalink)
Old 12-14-2011, 02:48 AM
yaww's Avatar
Thanks. So does it fit to original motor mount provisions at engine front, and i need to weld new mounts to the chassis to hold the Hurst frame?
  #23 (permalink)
Old 12-14-2011, 07:44 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
I dont know how your fabrication skills are, but you can very easily fabricate a mounting system that would resist torque. If it were mine I would use plate steel to duplicate that old mount in the HAMB link above and use a pair of shackle bushing mounts, one at each end, to attach to the frame. Here is a cheap shackle bushing kit. It is way cheaper than any "motor" mount kit you will find and it is the same stuff.
http://www.offroaddesign.com/catalog...assemblies.htm
  #24 (permalink)
Old 12-14-2011, 08:16 AM
RWENUTS's Avatar
There are several different front saddle mounts styles. Check google images. Search for motor mounts or hurst motor plate and all kinds of them come up. That's how I found the link for you.
I talked to an old buddy who has a 56 nomad. He uses side mounts on the tranny and has no clearance issues for his linkage. He has his 327 and 200r4 front mounted, trans side mounted and trans rear mounted with no problems.
  #25 (permalink)
Old 12-20-2011, 09:52 AM
yaww's Avatar
I paid a visit to my garage.
1) Transmission mounts will be very difficult to install since almost whole throttle linkage passes thru the place where these mounts are supposed to be.
2) Hurst type also need a wider chassis fixing, which i don't have space for
Question is, would it be fine if i use limit chain, front original motor mounts, and rear crossmember transmission mount. I don't have amonster installed, only stock 265 cuin?
  #26 (permalink)
Old 12-20-2011, 10:37 AM
RWENUTS's Avatar
Try a limit chain. Won't hurt. Don't make it tight. Leave a little slack in it.
I used a small turnbuckle with mine.
  #27 (permalink)
Old 12-20-2011, 10:57 AM
yaww's Avatar
Is there a certain market product, or simple steel chain?
  #28 (permalink)
Old 12-20-2011, 11:12 AM
RWENUTS's Avatar
Just a piece of chain will work. Bolt one end to the motor on drivers side and loop other end around the frame. Use small chain and bolts. 3/8 inch chain and whatever size bolt fit thru the link.
It doesn't need to be hooked on right at the front of the motor. Anywhere down the side will work.
I did a quick search. Here's alink for how the factory did it.
http://www.stevesnovasite.com/forums...d.php?t=115554
  #29 (permalink)
Old 12-21-2011, 08:20 AM
TurboS10's Avatar
Wiki Edits: 2
The GM recall/fix was very different than this situation! We are not talking about protecting against a motor mount separation until it can be fixed. This car has improper mounting points and a piece of chain just WILL NOT make it alright.
You need to fix the mounts properly IM(Not So)HO.
  #30 (permalink)
Old 12-21-2011, 08:46 AM
RWENUTS's Avatar
You are so right Turbo. He needs to fix his mounts. But it doesn't seem with all the links and suggestions that he'll be doing that. At least a limiter (chain) would delay the inevitable crash in his future when that motor flops over and stays on full throttle.
200R4 Help MI2600 Transmission - Rearend 3 11-07-2008 08:30 AM
200r4 MI2600 Transmission - Rearend 8 10-31-2006 09:02 PM
200r4 oldsmo Transmission - Rearend 1 09-27-2003 07:03 PM
200r4 MI2600 Transmission - Rearend 6 07-08-2003 06:48 PM
TH 350 to 200R4 bigjoedo Transmission - Rearend 1 05-02-2003 09:04 AM
