gas pedal and linkage on 56 chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2005, 09:55 AM
got a 56 Chevy swapped out 235 for a 350 now the throttle linkage will not work on the 350 it has the standard q-jet carb what do people usually do for throttle hook up go cable and if so does someone make a kit or is it not to bad to do it yourself thanks like how will it hook up to the pedle that is there or do i need somthing different
Old 04-25-2005, 10:05 AM
poncho62's Avatar
Wiki Edits: 5
You could probably easilly swap in a cable system from a 70s or 80s GM.....quite similar to the original 56 setup. I used the original on my 55...........trouble was, it kept locking at full throttle........lots of fun when that happens.
Old 04-25-2005, 01:06 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
You can get one that works from this place.
http://www.lokar.com/
Luv the smell of NITRO in the morning.
Old 04-25-2005, 02:04 PM
MI2600's Avatar
Member# 3287
When we swapped out the L6 in the '67, there was a linkage problem using the original rod linkage. The major problem was getting the carb to fully open. I had to fabricate a metal bellcrank of sorts and attach it to the carb linkage. It was hidden by the air cleaner. After that I scavenged every linkage rod I could find from junkyards and swap meets. They come in handy. Seems like every time you change carbs it opens up a whole new world of engineering opportunities.
Lokar Gas Pedal Installation? fairlaniac390 General Rodding Tech 2 02-13-2005 09:52 AM
Gas Pedal linkage bracket zeeman19 General Rodding Tech 5 05-21-2004 12:03 AM
