Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - gas powered compressor pump
Old 06-06-2011, 11:22 AM
matt167 matt167 is online now
Wiki Edits: 31
I do not have 220v and I have a 110v compressor which runs for the most part 'ok'. I can paint with it and for a 110v compressor ( HF 90234 ) it works great.. But I'v had an idea to run a 2cyl compressor pump with a 6.5hp gas engine. I could get a 10 gallon air tank from harbor freight repair parts I think, otherwise, a couple 10 gallon portable air tanks flipped upside down would do..
Where would I get the throttle actuator, or an electric clutch to make it work?
