Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - gas powered compressor pump
Old 06-06-2011, 02:33 PM
matt167 matt167 is offline
Wiki Edits: 31
I was thinking about an A/C clutch. being I have the compressor from a '75 Lincoln. But the local small engine shop may have an electric PTO clutch kicking around.. Might possibly use the PTO drive setup from my '68 Sears Suburban 12hp. Just back the mower up till the belt was tight, and run an unloader valve... That reed valve pump would get hot tho
