Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - gas powered compressor pump
Old 11-27-2011, 05:04 PM
matt167 matt167 is offline
Wiki Edits: 31
Well, digging this post out of the grave. HF has there 212cc Predator 6.5 HP's on sale with a coupon for $99.99 and I ordered 1 to at least have that part. I'm also going to use the 2hp rated single cylinder pump instead of the 2 cyl. The extra $200 for the engine large enough for the 2 cyl wasn't worth it
Is This the throttle control I need?
