Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - gas powered compressor pump
Old 11-28-2011, 08:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
212cc Predator 6.5HP
The link below has them calling the 212cc Predator 7 HP. They also seem to be a little concerned about using ZDDP because of the flat tappets. Personally I do not thing there's enough spring pressure to worry about it.
Seems that the Predator has different rods, cams, and piston/rings than the Honda GX 200 and clones. The 212 cc Predator has a 70 mm x 55mm B/S, the old engine was 68 mm x 54 mm.
5 reviews are available- http://www.harborfreight.com/Predato...:referralID=NA
From HERE:
