Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - gas smell hard start
Old 04-06-2007, 05:28 AM
sharkmonkey's Avatar
sharkmonkey sharkmonkey is offline
1973 Regal 455
Are the gaskets in the carb good? Can you see or feel gas leaking anywhere around the carb? How's your air filter? Maybe the A/F ratio is set too rich.
As far as hard starts, your timing may be set too retarded or you have a vacuum leak (or both). Could be a choke issue too. Do you have an electric, manual or divorced choke?
I'm just throwing things out that have bit me in the past.
MARK
