Motor oil has a higher viscosity than tranny fluid so I would use motor oil. First thing is to find out why gas washed down the cylinders in the first place. Was the carb float set too high or the needle & seat not closing the supply off, etc. If enough gas leaked down the cylinders to wash them, you can bet the gas went right into the oil pan. Fix the flooding problem and then change oil & filter before you run it too long.
Had this problem, and it took a couple of filters and oil changes to get rid of the gas... One has to watch on a brand new re-build that the beast is going to fire ASAP without cranking over and over esp after ALL that money and time.. Just to be sure we lined up #1 and spun the oil pump, turned engine 180 degrees did the same, then, another 180 same thing and lastly another one hundred and eighty degrees and spun the oil pump.. Maybe overkill, but it was a bracket engine and therefore bucks... Again, much importante to have everything set up (timing & carb primed) to fire ASAP...
Sounds like the foul came from fuel. Ck carb. especially if you have an electric fuel pump. Half hour of cam run in is not enough to seat rings. Moly rings are especially suspect to not seating in short run period. Requires several heat/cool cycles. Seating rings is also specifically related to cly. wall finish. Thus the "cross-hatch" hone pattern.
Change plugs, fix fuel flooding problem, install engine in vehicle, drive to seat rings. This is if cly to piston clearences are correct. |
| Carburetor Leaking Into Cylinders | mightycarlo10 | Engine | 12 | 04-15-2008 06:41 PM |
| gas | Bob C | Off-Topic | 10 | 03-06-2008 07:28 AM |
| A little perspective on gas prices | Centerline | Hotrodders' Lounge | 24 | 05-23-2005 02:50 PM |
| AV gas | Chevy Thunder2 | Engine | 51 | 03-21-2004 12:26 PM |
| want cheaper gas prices?? plz read this | sherfield2002 | Hotrodders' Lounge | 7 | 03-12-2004 05:22 AM |
