-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   gas tank (http://www.hotrodders.com/forum/gas-tank-106934.html)
pletcher 01-17-2007 09:39 AM
gas tank
I'm in the process of converting my 29 ford tudor to a rod I'm using a 32 frame and 32 tank tthe problem is the tank sets to far from the back of the body Ive seen other 29s with a 32 tank and thiers is much tighter than mine. the tank is app.4'' away from the differential any help>
Deuce 01-18-2007 08:37 AM
http://hotrodders.com/journal_photos...1456602171.jpg
http://hotrodders.com/journal_photos...1456602172.jpg
The tank sits back almost touching the spreader bar ... :)
I believe my tank is only 4 inches or so from the 9 inch Ford rear end ...but I have not measured it.
http://hotrodders.com/journal_photos...1431441691.jpg
On a original 32 Ford 3W coupe ... the body has a recess stamped into it ... to clear the fuel neck ... and a Model A is a shorter body ...
Deuce ... Moderator
