gas tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2007, 09:39 AM
gas tank
I'm in the process of converting my 29 ford tudor to a rod I'm using a 32 frame and 32 tank tthe problem is the tank sets to far from the back of the body Ive seen other 29s with a 32 tank and thiers is much tighter than mine. the tank is app.4'' away from the differential any help>
Old 01-18-2007, 08:37 AM
The tank sits back almost touching the spreader bar ...
I believe my tank is only 4 inches or so from the 9 inch Ford rear end ...but I have not measured it.
On a original 32 Ford 3W coupe ... the body has a recess stamped into it ... to clear the fuel neck ... and a Model A is a shorter body ...
Deuce ... Moderator
POR-15 gas tank resto kit cruzinTLT Body - Exterior 1 06-06-2006 05:08 PM
Gas Tank 1970 Chevy Camero kan Engine 0 05-21-2006 11:57 AM
32 'Tanks' gas tank - fuel surge/starvation? Limey Simon Engine 2 07-30-2004 01:18 PM
gas tank pressuring up montea General Rodding Tech 3 06-04-2004 08:37 PM
original 1936 ford gas tank fitting bomo General Rodding Tech 5 12-04-2003 04:20 PM
