Gas Tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2011, 12:51 PM
txdrifter's Avatar
cap'n crunch
Last journal entry: Project Monte
Gas Tank
Hi folks. I'm working on this tank. I've stripped the paint, pulled the dents, and sanding the bare metal with 80 grit. What should be my next step? I'm trying to learn this art but self teaching sometimes is a rough way to go. anyway I have some SPI. epoxy primer to shoot on it, but should I shoot it over the bare metal, then work the 80 grit scratches out? or use a high build polyester primer? thanks...Randy
Old 10-07-2011, 03:55 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
How about shooting a nice coat of POR15 cast iron (grey) and call it done. Do the straps in black.
Old 10-07-2011, 05:57 PM
sqzbox's Avatar
My pipes are my music
Before I installed the new tank in my mud truck I coated it with a can of black undercoating in a spray can. It's been two yrs. and it's still on there.
Old 10-07-2011, 10:31 PM
txdrifter's Avatar
cap'n crunch
I'm sorry I should have stated it's a Motorcycle Gas tank. I'm sorry for that...Randy
Old 10-08-2011, 05:46 AM
Old Fool's Avatar
Put the SPI epoxy on first, then your polyprimer.
Old 10-08-2011, 07:07 AM
Yeah, I agree with Old Fool SPI epoxy first then if you have anymore bodywork to do then do that and then put on the polyester primer. Sounds like you've got all the right materials and good luck you can do it!
Old 10-08-2011, 10:11 AM
txdrifter's Avatar
cap'n crunch
Thanks. It's been a while since I've done any of this. I didn't know much before, and done forgot thjat. LOL
Is this Gas Tank neck bad? Tank? Clean it? Leave it? gotmud Engine 2 07-06-2011 12:43 PM
keg tank(again i know) J-Sull Hotrodding Basics 5 09-15-2009 05:51 PM
DYI Hot tank PHATHOM Engine 3 06-23-2006 09:31 PM
gas tank th2hh General Rodding Tech 5 04-13-2004 09:38 PM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 05:13 PM
