Gas tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2012, 08:40 PM
Gas tank
Can a stock 1929 ford gas tank be used with a corvette engine?
I'm trying to use a carter P4070 electric pump mounted near
the stock corvette fuel pump area.
Gas tank is above the engine.
Old 05-04-2012, 09:47 PM
327NUT's Avatar
It probably can ....but you're going to have issues with the dist. hitting the firewall necessitating the engine being moved forward too much and then you'll have issues with the fan/water pump hitting the radiator. A lot easier, although more costly is to remove the stock gas tank (which also opens up the area under the dash) and install saddle tanks or a tank in the rear. Now you have room to notch the stock firewall or to install an after market unit that is already set up for a sbc.
Is this Gas Tank neck bad? Tank? Clean it? Leave it? gotmud Engine 2 07-06-2011 01:43 PM
gas tank help jaslong Hotrodding Basics 15 11-16-2009 11:37 AM
air tank as gas tank? matt167 Hotrodding Basics 22 11-04-2009 07:56 AM
gas runs back to gas tank... 66nova guy Engine 7 12-28-2003 05:35 AM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 06:13 PM
