Gas tank for 31 ford coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2011, 10:31 PM
Last journal entry: Back At Work
When I bought my project 31 ford coupe the gas tank was in the trunk. It was leaking and I removed it. As I am now rebuilding the car I was going to add a 32 tank because I think it looks good. It is expensive however so I am thinking of the trunk mount again. I feel I must put a steel firewall between the seat and the tank. Any opinions about this? Thanks Les
Old 04-12-2011, 02:05 AM
Gas tank for a 31 Ford
Use a search engine on the web or go to Ebay. I needed one for a '32 Chevy and found it that way. I had a choice between new stainless or refinished original. I took the stainless.
Normbc9
Old 04-12-2011, 05:17 AM
Irelands child's Avatar
Tanks, Inc have a 'universal' tanks that can be used:
http://www.tanksinc.com/index.cfm/pa...cat/cat133.htm
And yes, a good firewall is a must, IMO
As far as doing a '32 mod - not a job for the faint of heart even using the Dagle 'kit' (http://www.dagelsstreetrods.com/gas%20tank%20kits.htm)
This is mine - upside down after cleaning up my welds:
During assembly:
Assembled
And no, I did not use the Dagel kit but did my own engineering and design as I felt the kit compromised some strength. Total cost: tank, frame horns and covers, spreader bar, steel - about $550.
Dave W
Irelands child
Old 04-12-2011, 10:33 AM
During assembly:
Assembled
Dave W
Thanks Dave great pictures and wonderful information. Do you have a firewall behind your seat into the trunk? I think a steel floor in the car will act as that? Les
Old 04-12-2011, 12:31 PM
Les - the firewall is the trunk floor, which in this case is an almost flat piece of steel rather then a rumble seat riser. I figured the tank in the rear ala '32 was better then 10 gallons in your lap as the 'A' came with and 10-15 in the trunk using what little room was there after I installed a battery. But, like I said - it is a lot of work especially if the body is on the chassis.
As far as a firewall, I have the upholstered wrap around inner panel in the pass. compartment and another in the trunk. The space between is my wiring module along with a bunch of reinforcing steel:
The upholstered trunk lid panel has been removed for repairs - if the upholsterer ever gets to them . If not, I'll do them myself
Dave W
Irelands child
Old 04-12-2011, 10:29 PM
Thanks Dave. I will proceed with the gas tank. I can do this. It just might take a couple of weeks. My project journal is 1931gt Les
34 Ford Gas Tank? Samm Well Hotrodding Basics 1 03-22-2010 08:35 AM
35 Ford Coupe front clip on 35 Ford truck 35hotrodtodd General Rodding Tech 8 12-27-2007 02:00 PM
40's Plymouth coupe gas tank??? hemicoupe Hotrodding Basics 6 03-04-2006 11:39 PM
41 plymouth coupe gas tank hemicoupe General Rodding Tech 4 02-14-2006 03:55 AM
putting a ford in my forty ford coupe john kerr scotland Engine 6 08-07-2003 10:34 PM
