-   -   gas tank for 50 chevy truck (http://www.hotrodders.com/forum/gas-tank-50-chevy-truck-221460.html)
doubletree 07-09-2012 08:12 AM
Hi:
I want to install an after market gas tank in my 50 chevy truck but I have a rear crossbar shock support that is in the way for most tanks. Does anyone know what might work? Thanks
MARTINSR 07-09-2012 09:11 AM
There's plenty of room behind the rear axle. I put a 64 Nova tank in mine right there and it looked like it came that way.
doubletree 07-09-2012 09:20 AM
Thanks for the reply Brian, Did you mount the tank to the frame or use straps? Also where did you put the filler tube?
Larry
MARTINSR 07-09-2012 12:15 PM
I ran a 1 inch square tubing across the frame in front of the tank and ran straps under it to the rear crossmember. The filler was in a door I made using a hinge from a 60s Chevy in the fender.
MARTINSR 07-09-2012 12:19 PM
Of course you could do what I am doing when I rebuild it, that would be running a 47-48 tank inside the right frame rail with a filler out the lower bed extension just as it was when new. The tank was moved to behind the seat in 49.
doubletree 07-09-2012 03:15 PM
Good idea. I'll have to measure to see if my inside tank will fit. The tank is still good.
MARTINSR 07-09-2012 03:56 PM
I'm sorry if I wasn't clear, it was a different tank in 47-48, completely different shape.
