gas tank for 50 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2012, 08:12 AM
Hi:
I want to install an after market gas tank in my 50 chevy truck but I have a rear crossbar shock support that is in the way for most tanks. Does anyone know what might work? Thanks
Old 07-09-2012, 09:11 AM
There's plenty of room behind the rear axle. I put a 64 Nova tank in mine right there and it looked like it came that way.
Old 07-09-2012, 09:20 AM
Thanks for the reply Brian, Did you mount the tank to the frame or use straps? Also where did you put the filler tube?
Larry
Old 07-09-2012, 12:15 PM
I ran a 1 inch square tubing across the frame in front of the tank and ran straps under it to the rear crossmember. The filler was in a door I made using a hinge from a 60s Chevy in the fender.
The Following User Says Thank You to MARTINSR For This Useful Post:
doubletree (07-09-2012)
Old 07-09-2012, 12:19 PM
Of course you could do what I am doing when I rebuild it, that would be running a 47-48 tank inside the right frame rail with a filler out the lower bed extension just as it was when new. The tank was moved to behind the seat in 49.
Old 07-09-2012, 03:15 PM
Good idea. I'll have to measure to see if my inside tank will fit. The tank is still good.
Old 07-09-2012, 03:56 PM
I'm sorry if I wasn't clear, it was a different tank in 47-48, completely different shape.
doubletree (07-10-2012)
chevy, truck
Gas Tank - help needed 48 chevy panel truck billymike General Rodding Tech 4 04-16-2009 10:40 PM
Gas tank swap for 55 Chevy truck gator412 General Rodding Tech 8 04-05-2007 01:40 PM
47-48 chevy truck gas tank 49_chevy_truck General Rodding Tech 8 01-25-2006 04:56 AM
gas tank 56 chevy truck ksm General Rodding Tech 3 05-02-2004 12:33 PM
47 Chevy truck gas tank for sale WoodsEdge Engine 0 02-16-2003 06:18 PM
