gas tank anti squeak pads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2013, 09:04 PM
68 firebird's Avatar
im am about to change my gas tank but forgot to order antisqueak kit.was wondering if i could cut up an old pair of neoprene waders and use them to do the job.any comments would be greatly appreacated. thank you
Old 03-28-2013, 10:58 PM
BOBCRMAN@aol.com's Avatar
Should work. Many older cars had tar paper.
Old 03-29-2013, 05:23 AM
thanks bob i figured that it would work im putting it in this weekend.besides gives me a use for them im a big trout fisherman and have a couple pairs that leak.nice to find a use for them.thanks again
Old 03-31-2013, 11:54 AM
1971BB427's Avatar
I use old tire tubes between the tank and strap to isolate the mounts. Use them on numerous other places in car builds too. They work great, and free at most tire stores.
Old 03-31-2013, 12:06 PM
LATECH's Avatar
I used tarpaper cut with a straightedge. looks OE. It is also oily/greasy and repels water,and where the paper touches the tank is also oily. Should help it from rusting out under the straps.
I would think that waders or vynil material would hold water and also make static electricity. Just a thought.
Fact is stranger than Fiction
Old 03-31-2013, 01:19 PM
thank u for the responses to my post.the reason i thought of the waders is because i was reading what the antisqueak kit was made out of and it said that it was a spongy type of neoprene and i figured that was exactly what the waders were made of.i never thought about the static electricity they might put out.i would like to hear more info if anybody knows if they do put out a static charge.last thing i want is to blow up my car and myself due to a spark.thanks again for your replies
Old 03-31-2013, 01:21 PM
does any body know a way that i could test them to see if they can cause a static charge
front fender anti squeak kit tbrown8338 Body - Exterior 1 09-30-2011 11:27 PM
Is this Gas Tank neck bad? Tank? Clean it? Leave it? gotmud Engine 2 07-06-2011 01:43 PM
Anti squeak/wear material (not Welting) 35WINDOW Hotrodding Basics 1 11-23-2010 11:38 AM
fuel anti spill valve for gas tank jbinwa General Rodding Tech 2 09-16-2007 09:57 AM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 06:13 PM
