gas tank cleaning - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2011, 10:35 PM
gas tank cleaning
I'm removing my gas tank from a 1986 z-28 because the gas smells like varnish and the car is losing power after 1-2 miles of driving.i need someone to tell me "how do you clean the tank out and with what chemicals
Old 11-10-2011, 07:55 AM
delawarebill's Avatar
clean'n a tk
eastman sells stuff to do that.. u can also use that and put some chain in it and shake it alot.. after cleaning and flushing u can put in a sealer..
Old 11-10-2011, 08:23 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The varnish can be removed w/acetone on a clean rag, by wiping through the fuel pump hole. But this has to be done very carefully so you:
don't breath the fumes
don't catch anything- including yourself- on fire
don't get it on bare skin or eyes- wear gloves and eye protection
This was the only thing that worked on my Jeep tank. It was so bad the varnish actually caused the pump to not work- stuck it like glue.
On a side note, if the engine loses performance after a few minutes/miles or driving, it sounds like it's related to going to "closed loop" operation. This is where the computer takes over and uses the O2 sensor, etc. to set the engine calibrations.
The first thing I'd do is pull the codes- even if the check engine light isn't lit.
Old 11-10-2011, 09:41 PM
tank cleaning
deleware bill,thanx and i will pull the codes to see what gives/kudos
Old 11-11-2011, 06:56 AM
Wiki Edits: 27
radiator shop ?
Some radiator shops will do them in their hot tank. I think the last one was $ 20, easier than dealing with the chemicals at home.
cleaning a gas tank Tryin2MakeIt Hotrodding Basics 11 03-17-2013 12:39 PM
Gas Tank Cleaning davlonghauler Hotrodding Basics 5 01-29-2011 03:52 PM
cleaning out a gas tank David G General Rodding Tech 3 03-03-2008 10:41 PM
gas tank cleaning johnc486 General Rodding Tech 5 09-18-2006 10:47 AM
cleaning a old gas tank gasserman1941 Hotrodders Site Suggestions and Help 3 06-15-2006 07:16 PM
