Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gas tank filler
Thread: Gas tank filler
Old 05-13-2008, 07:40 PM
guba_unus's Avatar
guba_unus guba_unus is offline
Learning from your mistakes
Last journal entry: CS-144 alternator
I'd like to use the tank out of a small truck, but have yet to find one that is mounted behind the rear axle. I have a 4-link that fills the space where the normal saddle tanks go. I'd also like to stick with the current tank as I have quite a bit of money in it and it's setup already. The only change I want is to move the filler to the passenger side, but I worry if the gasket for the filler is below the gas level in the tank, then it is likely to leak. Am I worrying too much?
