Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gas tank filler
Thread: Gas tank filler
Old 05-13-2008, 06:47 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Lost in the 60's
Wiki Edits: 4
My advice if you want to use the tank you have is to take the tank to a professional and get him to move the neck where you want it. A pro will braze the neck on and braze a patch or plate over where it used to be and then you won't have to worry about leaks. Do not try it yourself...let a pro that know how to do it and keep things safe...no need to blow yourself up over a gas tank. Some welding shops will do this as well as some radiator shops.
