gas tank or fuel cell? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2010, 01:36 PM
RCMJ's Avatar
I am getting ready to work on fue system om my 1938 chevy. I was wondering if i would be better off putting a stock gas tank or a fuel cell in, which wouldbe mounted in the stock location. Does anyone have any pros or cons on this subject? Thank you all.
Old 11-13-2010, 02:31 PM
techinspector1's Avatar
Wiki Edits: 326
38 Chevy what? Coupe/Sedan/Pickup?
Old 11-13-2010, 02:59 PM
RCMJ's Avatar
Im sorry it would be a sedan
Old 11-13-2010, 04:16 PM
Wiki Edits: 326
If it were mine, I'd install the stock size and shape tank back in there. I'd run a 1/2" supply line and a 1/2" return line. You can use the return line in the event you need to reduce pressure to prevent overpowering the needle and seat in the carb (if you are planning to use a carb). Use a regulator that has a "return to the tank" port on it. Use 5 lbs max for a Carter AFB, Edelbrock Performer and Rochester Quadrajet. Use 6 lbs max for a Holley. I'm sure you can find several sources for a stock type tank, but just to get you started, here's a 17 gallon poly unit from Parr Automotive....
http://www.parts123.com/parts123/yb.dll?parta~partsort
Old 11-13-2010, 08:04 PM
bigdog7373's Avatar
Of course it's fast
Old 11-13-2010, 08:19 PM
Wiki Edits: 326
I guess my link went stale. Here's another....
http://www.parts123.com/parts123/yb....Z5Z5Z50000042b
What's the best carb & fuel tank replacement for a 1955 Chevy 235 straight six? islandman Engine 5 09-17-2011 10:50 PM
I need help with my fuel cell cap 70Velle350 General Rodding Tech 11 05-26-2008 08:06 AM
Gas Tank Venting - Help leejoy Engine 3 01-29-2007 08:25 PM
Revamping Fuel System topdogger Engine 6 12-29-2006 12:13 AM
custom floor and fuel cell 16grem72 Interior 1 02-08-2005 02:30 PM
