Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 12-24-2005, 01:26 PM
Skipr Skipr is offline
Gas tank leak. help plz
Hi all,
I have a bit of an emergency. I'm at my sister-in laws and she got a small hole in her gas tank. She just had a new one put in a year and a half ago and it is leaking again. They put a new tank in but did not fix the cause. The exhaust pipe is rubbing a hole in it. I was wondering if I could just use some of the Permatex gas tank putty on it and move the exhaust a bit. Anyone use this stuff?
Please help!
Merry Christmas
Walt and sister-in-law
Old 12-24-2005, 01:44 PM
302 Z28's Avatar
302 Z28 302 Z28 is online now
Moderator
re: Gas tank leak. help plz
You prbably will not be able to get anything to stick to it as long as it is wet. Once it is dry I would use some two part epoxy on it, but the tank really needs to be replaced to be safe.
Vince
Old 12-24-2005, 02:32 PM
Classix_Lover's Avatar
Classix_Lover Classix_Lover is offline
Air Raid Siren=Inspiration
I've heard that the putty works fairly well depending on how large the hole is. If it was just a tiny hole, I wouldn't mind giving that putty a try but make sure the tank is empty so it can be nice and dry for the appropriate bond. As 302 mentioned, it would probably be better to replace the tank but first figure out a way to relocate that exhaust furthur away from the tank!
Old 12-24-2005, 04:38 PM
machinestheman machinestheman is offline
just out of the blue why is the exhaust rubbing you should check youre system for broken or worn out mounts or maybe its bent which can seriously hinder performance hand in hand with gas mileage, save youre self more money and heartache and make sure the root problem is taken care of
i learned the hard way fix the problem not just the symptoms, im working on my fifth engine rebuild because of a faulty intake system
Old 12-24-2005, 06:47 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Originally Posted by Skipr
Hi all,
Please help!
Merry Christmas
wire brush it off, use the 2 part gas tank repair epoxy stick froom the parts store that sticks fine when wet with gas...... I had one repair that lasted 5 years.
Old 12-24-2005, 08:02 PM
docvette's Avatar
docvette docvette is offline
Moderator
 docvette's barnstar
Wiki Edits: 12
Doc here,
Heat, Sparks and Fuel....Hummm...I think I'll take the bus....
Move and solid mount that pipe!!!
Then assess the amount of damage to that tank, If it has worn through twice..It may have given it's all..and a better plan would be replacement..
If you Do repair it, and you can't get a bunch of distance between Ignition source and fuel source (pipe & Tank) Glue a sheet of rubber pad (a computer mouse pad would work..) , about 1/4 inch thick to that area of the tank in case it ever hits it again..
Don't go Blazin any trails...
Doc
"On Eldebrock, On, Isky, On Hemi, On Blitzen.....On Comet, On Cupid, On SBC.."
Slay Bells my ***....NOX2 Powered Reindeer....
Rudolph Had a Lean Cylinder..see the Right Header GLOW?
Aftermarket Solutions
Electronic & Electrical
Innovations
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Gas tank leak. help plz"
diesel in gas tank help asap mike69scj Engine 15 05-30-2004 09:52 PM
Torino wont stay running 79firebird350 Engine 4 05-20-2004 12:38 PM
'67-'72 Chevy gas tank peytonta General Rodding Tech 5 05-14-2004 06:42 PM
original 1936 ford gas tank fitting bomo General Rodding Tech 5 12-04-2003 04:20 PM
gas tank suction screen superford61 Hotrodding Basics 5 10-01-2003 08:34 PM
