gas tank neck - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2008, 04:41 PM
gas tank neck
This does not pertain to a hot rod, my daily driver is a 98 lumina. Quite a while back someone tried to siphon gas out of my tank and damaged the little flapper in the neck. I did't think too much of it until now, when I have to go to inspection. I think I'm going to fail for this. Do they offer a replacement part for this or will I be looking at a new tank? Thanks Joe
Old 08-22-2008, 05:01 PM
They check your flapper valve during inspection up there????
Shane
Old 08-22-2008, 05:50 PM
gas tank neck
they check it here in middle Tennessee .
they make a piece to replace it , but it usually falls in tank after a while .
i cut mine off and grabbed a neck at junk yard and spliced with hose and clamps .
next time leave them a lighter , they might need it to see .
BOOM !
Old 08-22-2008, 09:29 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Actually i would check car-part.com to see if any of the local yards have one of those..the neck is seperate from the tank so should be fairly easy fix..
Sam
Old 08-23-2008, 02:53 PM
BOOM !
Wow about all they check here is lights,horn wipers,and brakes(one shop) if they dont know the car.
Gas tank filler guba_unus General Rodding Tech 4 05-13-2008 06:47 PM
Diesel pumped in new Corolla Gas tank michael2 Engine 21 05-05-2008 11:29 AM
Camaro 70-73 gas tank question kdj997 Body - Exterior 1 02-20-2008 11:21 AM
2nd Gen Camaro Gas tank question kdj997 Body - Exterior 1 01-28-2008 07:51 AM
gas tank pressuring up montea General Rodding Tech 3 06-04-2004 08:37 PM
