Is this Gas Tank neck bad? Tank? Clean it? Leave it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2011, 08:21 PM
gotmud's Avatar
Last journal entry: "Merlie" a 1964 Chevrolet C10
I've been working on finishing up a 64 C10 for a while and am getting to the gas tank. The tank, from the PO, looks like it could have been new but I dont really know. Pics attached.
My question is about guessing about the inside condition. When I look down the cap, I see white residue that is powdery.
Do you think a clear fuel filter will catch this once I start filling it up,
do I need to pull it and clean it some how,
or do you think I need to rip and replace?
I got it cranked today and she sounds so sweet....but I am just using a fuel line, re-routed from the fuel pump, stuck down the neck of a plastic gas can.
Thanks
Glenn
ID:	56528   Click image for larger version
Old 07-03-2011, 10:37 PM
evolvo's Avatar
Heathen
You could try pulling the fuel level sender out and using a good light and mirror to have a look. Or get a tank cleaning and sealing kit and be done with it.
http://www.google.com/products/catal...ed=0CHIQ8wIwAw
Old 07-06-2011, 12:43 PM
gotmud's Avatar
I think I just decided to take it to a local radiator shop to get it cleaned and coated. It was really really bad inside.
Thanks
Gas Tank Filler Neck options? JhnBrackett Body - Exterior 10 09-05-2011 09:40 PM
Gas Tank filler neck HaydenP Hotrodding Basics 3 06-14-2011 11:56 PM
gas tank neck fiddyfofoad General Rodding Tech 4 08-23-2008 02:53 PM
manifold filler neck or expansion tank? lumberjacknooj Engine 6 01-22-2008 05:28 AM
Not sure which board is best? Gas tank neck? grumpy1 Engine 6 11-26-2007 07:38 PM
