gas tank options? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2007, 07:03 AM
okeesignguy's Avatar
gas tank options?
a street rod i just bought has a funky, plastic fuel cell and i want to upgrade to a round aluminum type...
any recomendations?
i have included a pic of the fuel cell that is located in the trunk if that helps...
thanx for any help given
Old 09-23-2007, 07:34 AM
http://www.speedwaymotors.com/p/2530...num-Tanks.html
http://www.speedwaymotors.com/p/494,...num-Tanks.html
http://www.speedwaymotors.com/m/419_...Fuel-Caps.html
That what your looking for?
Shane
Old 09-23-2007, 07:42 AM
yes Sir....i have seen them online...are they good quality?
what about sending unit for fuel guage? how does that work?
THANX...
Old 09-23-2007, 08:09 AM
Vortech 4.3's Avatar
jack of all trades
THANX...
looks to me that you would have to have that added on = $$$
Old 09-23-2007, 11:04 AM
bentwings's Avatar
bentwings
There are several sending units depending on how your gage reads. 0-90 ohm and a reverse 90-0 ohm and I think the other is a 300 ohm (ford I think) They also come in 8 and 12 inch lengths. I just got mine from Speedway. Figure about 100 bucks +/- a little. You would have to have the bung welded in. I made my own and welded it in to my own aluminum tank.
Old 09-23-2007, 11:11 AM
Your Chevy looks better than my '31 A did when I bought it-loosely mounted boat tank in the trunk with all kinds of weird hoses, clamps and bits and pieces.
I went with a 16 gallon rectangular steel tank form Tanks,Inc. Didn't get it from Tanks directly. Those people were weird to deal with! Called the factory-couldn't pick it up, might not have one in stock, didn't know the price, didn't know their hours-even though they had a big ad with their info in Street Rodder.
I got mine form Yogi's in Iowa. Great folks to deal with, including returns ( I got the wrong sender). Make sure you get a roll-over proof vent. The sending unit was ordered separately and needs to match your fuel gauge to read properly. I run bizarre Faria gauges and it took us a while to figure out what Ohm range I needed. If you're using new or standard gauges the mfg. should have it listed.
PM me if you want photos.
Old 09-23-2007, 11:16 AM
cboy's Avatar
Last journal entry: Finished
This is the 14 gal tank (12" x 30") I'm putting on my new project. I got it here http://www.dansperformanceparts.com/...buggyfuel1.htm which seems to have a little better selection and slightly better prices than Speedway. This tank was $200 - with no sending unit but everything else ready to go.
Always learning...and sharing what I've learned.
Old 09-23-2007, 12:29 PM
i like this tank...
if i go with it, where do i get a sending unit from?
i know i will have to weld in a bung...
do the units come with a bung?
any ideas and suggestions would be appreciated...
Thanx...
gas tank in Model A pcoghlan General Rodding Tech 17 03-29-2006 11:05 AM
Gas tank leak. help plz Skipr Engine 5 12-24-2005 09:02 PM
32 'Tanks' gas tank - fuel surge/starvation? Limey Simon Engine 2 07-30-2004 02:18 PM
gas tank pressuring up montea General Rodding Tech 3 06-04-2004 09:37 PM
original 1936 ford gas tank fitting bomo General Rodding Tech 5 12-04-2003 05:20 PM
