Gas Tank Plugged - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2005, 07:38 AM
Granddad's51's Avatar
Last journal entry: Fender Skirts added
Gas Tank Plugged
After not being able to get gas to the fuel pump I pulled the sending unit and looked in side. YUK there is 20 years of "gunk" clogging the bottom of the tank.
IS there a product to clean this stuff out or should I order a new tank?
Old 07-11-2005, 07:53 AM
johnsongrass1's Avatar
Race it, Don't rice it!
MEK if you want to mess with it.
Old 07-11-2005, 08:30 AM
edge's Avatar
Time is short, are you ready?
Originally Posted by Granddad's51
... or should I order a new tank?
20 years old, what car? Only asking because it may be just a easy and better to replace the tank. That is what I did with my 1981 Camaro. I can't remember exactly, but it was like $150. Since it was new, I had a drain plug added so that I can always flush it out later if needed. Ed www.edgesz28.com
Old 07-11-2005, 08:38 AM
Technical Support Barry Grant
Clean or Replace tank?
If you don't need to change the fittings in the tank, and it's in OK shape other than the gunk inside. Remove it, and have your local radiator shop clean it out for you.
Old 07-11-2005, 10:24 AM
OK your right its 54 years old but....I ment It's been 20 years since the gas tank had gas in it!
Looks like a replacement will be $320. buck..OUCH!
Old 07-11-2005, 05:14 PM
A steam cleaner, not hot water but a true steamer works good. However if it is a steel or terne plate tank it's probably a waste of time. Alot of that gunk is going to rust and if it isn't leaking now it soon will be.
Old 07-11-2005, 05:51 PM
steve t's Avatar
ex biker, now hotrodder
buy a new tank, it will save you a lot of hassle in the long run,
Old 07-14-2005, 12:58 AM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
GAWD!! IS everybody but me made of money!!! *G* It's part of "hot rodding" to fix up old parts to work again. "IF" I were you, I'd have the old tank steamed out, then check out what the inside looks like. If you see rust then they make a special paint (can't remember the name) but it's made to coat and seal the inside of gas tanks, cost less then $50. BUT if you got the money then go for it! Get a stainless steel one ...they look WAY COOL!!! *G* My $0.02 anyway, GOOD LUCK! ...Mark
relocating gas tank out of truck cab murrsue General Rodding Tech 6 02-26-2005 01:12 PM
gas tank pressuring up montea General Rodding Tech 3 06-04-2004 08:37 PM
'67-'72 Chevy gas tank peytonta General Rodding Tech 5 05-14-2004 06:42 PM
Gas Tank .... problems 63novawagon Body - Exterior 1 04-25-2004 11:26 AM
Gas Tank Plumbing Follow-Up Doc68 Engine 0 01-11-2004 07:28 PM
