gas tank problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2013, 05:45 AM
gas tank problem
purchased street rod, having problem when putting gas in tank, gas spits back out, no vent tube that I can see, any suggestions? It is a ten gallon tank.
Old 06-09-2013, 06:27 AM
Irelands child's Avatar
Ya gotta give us more then what you have. Miracles can happen here but there just isn't any way with that little bit of info. Pictures, description, car build - whatever
Irelands child
Old 06-09-2013, 06:45 AM
delawarebill's Avatar
spit'n fuel
what size fuel neck is on the car/truck ??? u don't need a vent, so i'm thinking there is a restriction or something..
Old 06-09-2013, 07:08 AM
Banned
with a 10 gallon tank you are putting the gas in to fast. think of it as a harley you do not fill it up full force.
Old 06-09-2013, 07:35 AM
Wiki Edits: 27
Add a vent
If the tank has a small filler neck it needs a fill tube vent to let the air out, the vent should be connected to the main fill tube above where a gas station nozzel ends, that way the tank is sealed when the cap is installed and it should have a combination vent-roll over valve on the top of the tank. As a side note when I was an engineer at Ford an accountant was crunching numbers and found that Ford had about 3 times as much profit margin on the 3 gallons of gas they put in each car, He proposed putting in more fuel and adding it to the window sticker invoice. He was given a new mustang for the suggestion. a few years later when the production rate increased there wasn't enough time without gas splashing out when the fill tube on the gas tanks started having the internal flapper valve. His idea was to add a 3 ft clear vinyl tube to the end of the fill nozzel and that put the fuel into the bottom of the tank and they could pump in 7 gallons in 40 seconds. No spills.
1951 Willys Truck Gas Tank Problem Dreamthief Hotrodding Basics 8 06-09-2013 12:29 PM
Is this Gas Tank neck bad? Tank? Clean it? Leave it? gotmud Engine 2 07-06-2011 12:43 PM
fuel problem gas tank or fuel cell 2006strat Engine 1 04-03-2011 01:15 AM
Problem with gas tank los48bombas General Rodding Tech 4 01-16-2009 12:49 PM
Need Tank Sender for Custom Gas Tank.... bg Engine 3 11-05-2002 05:13 PM
