gas tank question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2007, 02:19 PM
gas tank question
I'm working on a 35 chevy standard and wou like to use a 32 ford gas tank. Has anyone did this? The frame has been cut up and part of the metal in the rear is missing. I plan to leave the sheetmetal under the trunk area off. Would this be possible or should I just put it in the trunk. Trying to fill the void between the rear bumper and the body. Any suggestions would be appreciated.
Thanks
Old 06-27-2007, 10:40 PM
Metal Twister's Avatar
Change is Opportunity!
Last journal entry: One More Seat
Thanks
Build something that looks like a tank and stuff it in there. Then put your tank under the car. You could even put a working filler spout in the fake tank and run the tube to the real tank? You asked for "any suggestions" Good luck.
Gas Tank Vent fred56 Hotrodding Basics 5 02-21-2007 11:48 AM
Permatex epoxy (all metal) gas tank. 1Fast65Elky Hotrodders' Lounge 8 10-03-2006 03:00 PM
Gas tank question 3100 Special Engine 3 03-22-2006 06:15 PM
welding on a used gas tank mychevystang Garage - Tools 5 10-10-2004 10:33 PM
Which Gas tank is Best?? HotRodMan Engine 1 09-06-2002 10:19 PM
