There will be two tabs on the sending unit retainer ring. Use a flathead screw driver and tap the tab in the left direction. It will free upand i believe there is two "notches" on the ring that have to line up with two "female notches" to lift the ring off. When the ring is removed the sending unit will pull right out. (mind the float as you pull the unit)
Where is the leak in the tank?? Last edited by Indian; 09-02-2003 at 07:36 PM. |
If it was totally drained, aired out I might try tack welding it if you can see the leak. Or a high grade epoxy might work too. I'm in the army and use the mil-spec jbweld all the time to repair small holes in otherwise pita projects. We have one line of stuff that works extremely well. Held together a couple radiators on a 903 ci engine in the middle of death valley. Its called belzona. Website is: http://www.belzona.com Click on the belzona polymers for information. However I don't know how to purchase it outside of gov't supply channels. The stuff is pretty good. Highly flexible and easily machinable. Maybe the por-15 equivelant of jbweld?
![]() Really nothing to do with a gas tank but was just reading that they repaired the rudder on the Queen Elizabeth II 19 years ago with this stuff. Last edited by esears; 09-02-2003 at 08:23 PM. |
If your going to weld your gas tank be careful. If youve never done it before just take it to a radiator shop have them boil it out and solder it. If you are going to make the repair yourself have it boiled out first. Even if it is dry as soon as you hit it with a torch or welder you will have to walk two blocks to go pick it up, don't ask me how I know this. There are ways around it though. you can fill it with water except for the spot you are going to weld,or you can fill it with inert gas, argon carbon dioxide, carbon monoxide, whatever you have handy. then weld away.
Pleas! DON'T DO IT! Take it to a Radiator shop and have it repaired. You may have to look around to find a shop that will do it. Again do not do it! I have seen gas tank's that were washed out air out and left to air out for more than a month and it still blew up. I have heard that if you wash it out and then air it out and then put old coffee grounds in it and then wash it again that it will be safe! I don't believe it and would not try it. TAKE IT TO THE SHOP! It may even have more than one hole in it. --------------------------------------------------------------Gene Neal
Thanks for the advice. I will take the tank to a radiator shop and have it repaired. I got the sender out and the tank completly drained. I was using the bar of soap trick for awhile. I decided I should take it down and have it fixed, since the exhaust pipes run by both sides of the tank.
Kits
There are kits you can buy that are 3 step kits. One cleans out the tank completely of all rust and junk. The next step coats the whole inside and the last step does the sealing (I believe bonds to step 2's coating.) Works great.
I have also sealed gas tank leaks with this stuff that you had to knead together and then apply it to the leak. It sealed it up without even dropping or draining the tank. That was about 7 years ago and it still holding fine. I can't remember what it is called, but the stuff came in 2 rectangular packages and looked like clay. One was gray and the other was brown. Maybe someone else knows what I am talking about? (Honest.. I'm not crazy! hehehe) Rock on... Seņor |
