we use to have old tanks cleaned out .i dont know if anybody still does it or not. but you can get a new tank for around 200 bucks. Cole
The cleaning out is the hard part, I've done some tanks where I've put about a gallon of Marine Clean, then tossed in a big handful of 20 penny nails, 1/2" bolts, steel tumbling media, cap off all the holes and then shook the thing in every concieveable position till I was dizzy...with minimal rust removal...
I finally made a big rotisserie that hangs out of the backside of my lathe, it holds the tank, in several positions, and I turn it on slow speed for several hours....days even...Noisy is not the word to accurately describe the sounds that it makes...A million monkeys beating on a million garbage can lids is more like it...I have a 68 chevy PU in my shop right now with about 1/4 of bubbly rust on the inside, a new repro tank is about 140.00-180.00.. It's getting a new tank. If you can find someone (radiator shop) to clean out the tank, and seal it with one of the better sealers, and do it right, it'll probably cost close to as much as a new tank anyway.. Here is a thread with some links and suggestions for tank sealers and methods. Gas Tank - help needed 48 chevy panel truck Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
my new tank, straps, sending unit, tank pad, lock ring and filler neck grommet was $310 from ebay. Keep in mind some of those tanks come in bare steel and some come painted.....you dont want these as they will rust. The dodge tank i bought was made in canada.....the rest are made in taiwan. The canadian tank is either galvanized or coated somehow. The sending unit is stainless stainless steel and and has no wires wrapped around the sending unit pipe. This throws off the electrical values to the gauge. get one with a metal strip and make sure the sending unit is not plated. I have had many problems doing it the cheap way. some things you just dont want to go cheap one. THis is one of them.
tank http://stores.ebay.com/Tamrazs-Parts-Discount-Warehouse he has the canadian made tank for $169 plus shipping. cant beat that sending unit i only saw one used on there for $64 that was claimed to have worked but had no returns Last edited by glhx; 05-03-2009 at 01:59 PM. |
Year One has the tank for your Elky for $165, part number DG24. I'd go with Year One over an ebay seller, since you can call them back in a month and you know they'll still be there.
http://www.yearone.com/serverfiles/f...ain2.asp?cat=B |
| Diesel pumped in new Corolla Gas tank | michael2 | Engine | 21 | 05-05-2008 11:29 AM |
| Camaro 70-73 gas tank question | kdj997 | Body - Exterior | 1 | 02-20-2008 11:21 AM |
| 2nd Gen Camaro Gas tank question | kdj997 | Body - Exterior | 1 | 01-28-2008 07:51 AM |
| gas tank in Model A | pcoghlan | General Rodding Tech | 17 | 03-29-2006 10:05 AM |
| Gas Tank Cleaning/Flush? | The Vandal | Engine | 8 | 04-13-2003 09:27 PM |
