Gas tank sending unit - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2009, 07:34 AM
I have a aluminum cylindrical style gas tank in my Model A. The tank is approx. 25"X10"X10". Any idea how to mount a sending unit in it? It is not fuel injection.
Jerry
Old 10-01-2009, 04:45 PM
rwruther's Avatar
Last journal entry: new wires for the hot rod 39
what I did
My engine did not require an in tank fuel pump. The "sender" was just a variable resistor with a float mounted on a pivoting arm. When the arm pivots the resistance to ground changes...These things come with resistors sized for the gage and 12 or 6 volt systems. The instructions for the one I bought said to give about an inch below the float at the lowest point in the travel. I guess that's your reserve fuel a? My float arm turned out to be rather short, I figured it might booger up my gage reading, but it doesn't. It works like a champ. I just made sure the thing was in there vertical and the float didn't hit anything, boom-zoom away I went. Hope that helps.
R
PS Oh, I forgot, the float/resistor deal has to be the proper resistance and .... how do I put it?? When the tank goes to empty, some gages want to see more resistance happen, some gages want to see less resistance. You need to kind of match your "sender" to your gas gage and electrical voltage....wait a sec...here's Classic Instruments web site, this will fix you up!
http://www.classicinstruments.com/in...mentID=senders
Old 10-01-2009, 07:09 PM
302 Z28's Avatar
You will have to have the proper fuel sending unit bung either HeliArced, or TIG'd in place.
Vince
Old 10-01-2009, 07:40 PM
rwruther's Avatar
Vince
Where do we get a bung? ....you know, just in case we need one... (I have a bung now, I guess, but maybe I want to change out my tank and the next one will be um?...bung-less?) thanks! and sorry for assuming there was a bung if my post was lame...I just, you know, thought we had a bung already?
R
Old 10-01-2009, 07:51 PM
life is a temporary assignment
R
It can be made very easy, Take a piece of pipe, Weld a cap plate onto the end of the pipe.. It will have to be big enough for the unit to mount to..Cut it down to fit on to the tank.. Like you would be saddling a piece of pipe to another pipe.. Hope this help's..
Old 10-03-2009, 11:13 AM
bentwings's Avatar
bentwings
I have the aluminum cylindrical one from Speedway. I welded a 1/4 thick aluminum ring inside the tank when I built it. It has tapped holes to mount the sending unit.
Update the dang sending unit failed. The float expanded insid the tube and seized. I took it apart and unstuck up but the board also has an open circuit. It only had gas on it for a year. Don't know where it was made but I can guess.
Looks like another $90 to toss into the swirling black hole. It's getting just like having a boat.
Draining gas tank 96 F250 Furytom Engine 2 03-26-2009 12:02 PM
Oil Pressure Switch and Temp Sending unit jvgrago Engine 5 05-23-2008 10:38 PM
Gas Tank 1970 Chevy Camero kan Engine 0 05-21-2006 12:57 PM
universal fuel sending unit for pre-65 chev? murrsue Electrical 6 04-24-2005 05:10 PM
replacing gas tank in 29 Ford pikalpha Engine 2 12-10-2001 05:45 PM
