Gas Tank Sending Unit Ground Wire Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2007, 08:27 PM
daveh's Avatar
Hey guys,
I am replacing my gas tank on my 69 Camaro. I bought a new one and had it power coated. My question is do I have to attach the sending unit ground wire to the tank like the original or can I just splice it an attach it to another piece of metal or the frame? Thanks
Dave
Old 03-30-2007, 09:00 AM
brian0605's Avatar
mostly confused
Last journal entry:
I'm pretty sure it's got to be hooked to the tank. If the tank has the strap pads installed on both the top and bottom it is isolated and the voltage to the sender has no path back to ground. Brian
Old 03-30-2007, 11:14 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I would want the tank grounded to the frame also.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
how to connect wiring to sending unit zipfactor Electrical 2 05-12-2006 11:34 AM
sending unit/ gas gauge incompatibility murrsue Electrical 3 03-03-2005 08:02 PM
Gas Tank .... problems 63novawagon Body - Exterior 1 04-25-2004 11:26 AM
need help w/a GAS TANK & sending units TooMany2count General Rodding Tech 10 05-26-2003 07:57 PM
